Introducing IPAM: Pool-Based Container Networking
Containers in Pantavisor have always had a network namespace, but actually configuring it has been the user’s problem. You either left it on the host network (simple but brittle), wrote a pre-start.sh to bring up an interface (works, but every container reinvents it), or hand-rolled lxc.net.* lines into lxc.container.conf (works once, breaks the day you change bridges or subnets). For teams running fleets of devices with multiple containers that need to talk to each other, this got painful fast.
IPAM (IP Address Management) changes that. You declare named network pools in device.json once — bridge, subnet, gateway, optional NAT — and any container can opt into a pool with a single PV_NETWORK_POOL reference in its args.json. Pantavisor allocates the bridge, hands the container a stable IP, sets up MASQUERADE if you asked for it, and gets out of the way. Restart the container, reboot the device, run an OTA — the container gets the same IP back.
The Concept
A pool is a named L2/L3 segment. Define one (or several) per device:
  "network": {
    "pools": {
      "internal": {
        "type": "bridge",
        "bridge": "pvbr0",
        "subnet": "10.0.5.0/24",
        "gateway": "10.0.5.1",
        "nat": true
A container then references the pool by name. Pantavisor takes care of bridge creation, address allocation, and namespace plumbing:
  "PV_NETWORK_POOL": "internal",
  "PV_NETWORK_HOSTNAME": "net-server"
That’s it. The container comes up on pvbr0 with the next free address in 10.0.5.0/24 and can talk to any other container on the same pool. Because nat: true, it can also reach the outside world through the host’s default route.
Stable Leases
Allocations are keyed by (pool_name, container_name). When pantavisor sees a container by that name come up again — whether from a pvcontrol containers stop / start, from auto-recovery after a crash, or after a reboot — it reuses the existing lease instead of handing out a fresh address. Your services keep their identity across the operational lifecycle.
Per-Pool NAT
The nat flag is independent per pool. Want some containers internet-reachable and others on an isolated lab subnet? Define two pools:
  "network": {
    "pools": {
      "internal": { "bridge": "pvbr0", "subnet": "10.0.5.0/24", "gateway": "10.0.5.1", "nat": true  },
      "lab":      { "bridge": "pvbr1", "subnet": "10.0.6.0/24", "gateway": "10.0.6.1", "nat": false }
Only internal gets a MASQUERADE rule. Containers on lab can reach each other and the bridge gateway, but their packets are not source-NAT’d outbound — perfect for hardware-in-the-loop scenarios where you don’t want test traffic leaking onto the LAN.
Static Reservations
Pool allocation is dynamic by default, but you can pin a specific address by adding PV_NETWORK_IP:
  "PV_NETWORK_IP": "10.0.5.50"
Pantavisor honours the request as long as the IP is in the pool’s subnet and not already leased.
Coexistence with Legacy Containers
If you already have containers that bake lxc.net.0.ipv4.address directly into their lxc.container.conf (the pre-IPAM way), pantavisor scans for them at startup and reserves their addresses out of the pool before any dynamic allocation happens. New pool-using containers on the same subnet won’t be handed a colliding IP. You can migrate one container at a time without flag-day cutover.
NAT Backend: nftables Preferred
Pantavisor probes for nft and iptables at runtime and prefers nftables when available. The default Pantavisor appengine image now ships with nftables installed — no iptables binary needed (every distro kernel from 2014 onwards has the nf_tables backend). If you have a custom image without nftables, pantavisor falls back to iptables automatically.
Validation: Fail Fast, Refuse to Start
Two pre-start checks catch misconfigurations before any namespace work happens:
  • Unknown pool reference — if a container’s PV_NETWORK_POOL names a pool that isn’t in device.json, pantavisor refuses to start it. In a TESTING update this triggers rollback; in steady state, reboot.
  • Baked lxc.net.* + pool reference — a container can declare an IPAM pool or bake its own lxc.net.* config, but not both. Mixing them would silently leak orphan attributes when pantavisor rewrites the netdev type. The validate_config hook refuses such containers with a clear log line.
Default Pool: pvcnet
Every BSP shipped from meta-pantavisor now includes a default pvcnet pool in device.json:
  "network": {
    "pools": {
      "pvcnet": {
        "type": "bridge",
        "bridge": "lxcbr0",
        "subnet": "10.0.3.0/24",
        "gateway": "10.0.3.1",
        "nat": true
It binds to lxcbr0 for compatibility with any pre-existing lxc-native containers that might already be on that bridge — the reservation walk above means they keep working unchanged. Set PV_NETWORK_POOL: \"pvcnet\" on a new container and it gets a 10.0.3.x address with internet access out of the box.
How to Adopt
  1. Pull a recent build of meta-pantavisor master onto your device. The default pvcnet pool ships in the BSP.
  2. For new containers, add PV_NETWORK_POOL to args.json:
    { \"PV_NETWORK_POOL\": \"pvcnet\" }
    Optional: PV_NETWORK_HOSTNAME, PV_NETWORK_IP, PV_NETWORK_MAC.
  3. For new pools, add an entry under network.pools in device.json. Pantavisor creates the bridge on next start.
  4. For migration from lxc.net.*-baked containers, drop the baked entries and switch to PV_NETWORK_POOL. Or leave them as-is — the reservation walk keeps them working.
Reference Containers in meta-pantavisor
Working examples for every IPAM scenario live in recipes-containers/pv-examples/ — copy a recipe, swap in your own payload:
Recipe Demonstrates
pv-example-device-ipam Single-pool device.json (internal, 10.0.5.0/24, NAT)
pv-example-device-ipam-2pools Two pools — one with NAT, one without
pv-example-device-ipam-lxcbr Pool bound to lxcbr0 (legacy-coexistence)
pv-example-net-server Pool consumer with PV_NETWORK_HOSTNAME
pv-example-net-client Pool consumer doing a TCP connect
pv-example-ipam-valid Static reservation via PV_NETWORK_IP
pv-example-ipam-static Legacy lxc-native container with baked lxc.net.0.ipv4.address
pv-example-net-pvcnet Pool-using container on the default pvcnet pool
pv-example-ipam-nopool Negative case — references a non-existent pool
The 9-test IPAM testplan walks through each scenario end-to-end against the appengine image.
What Landed
  • pantavisor — IPAM subsystem (pv_ipam_*), reservation walk, validate_config hook, nftables-preferred NAT setup.
  • meta-pantavisor — example containers, default pvcnet pool in every BSP device.json, appengine nftables install, network.json support in container-pvrexport.bbclass, full testplan.
Try It Out
On a device with the latest meta-pantavisor build:
ssh -p 8222 _pv_@<device-ip>
ip addr show lxcbr0      # Default pvcnet bridge: 10.0.3.1/24
nft list ruleset          # MASQUERADE rule for 10.0.3.0/24
Deploy a pool-using container (any container, just add \"PV_NETWORK_POOL\": \"pvcnet\" to its args.json):
pvcontrol ls              # See the assigned IP
pvcontrol containers stop my-app
pvcontrol containers start my-app
pvcontrol ls              # Same IP — lease was reused
Look for these in the pantavisor log:
[ipam] created bridge lxcbr0 with IP 10.0.3.1/24
[ipam] setup NAT (nftables) for pool pvcnet
[ipam] allocated 10.0.3.2/24 to my-app from pool pvcnet
[ipam] reusing existing lease for my-app: 10.0.3.2/24
Coming in 028
IPAM lands in the Pantavisor 028 release, where it ships in the prebuilt binary images you can flash directly onto a Raspberry Pi or any of the supported boards — no Yocto build required to try it out.
If you want to play with it sooner: watch this space for a 028-rcX drop in the coming days. The release candidates carry the same IPAM bits as 028 final and are the easiest way to kick the tires before the GA images go up.
Links
