New documentation site: docs.pantavisor.io
Hi everyone,
Our documentation has moved to a new home: https://docs.pantavisor.io/
The old site at https://docs.pantahub.com/ has been migrated over, so everything you were used to finding there is now on the new domain. If you have bookmarks or links saved, please update them.
A few things worth highlighting about the new site:
Versioned documentation. The docs are now published per release revision, so you can browse the exact documentation matching the version you’re running instead of always landing on the latest.
New tutorials. We’ve added step-by-step guides to help you get going faster, whether you’re building your first device image or getting familiar with the workflow.
Expanded reference documentation covering:
  • Pantavisor — the core runtime
  • meta-pantavisor — the Yocto/OpenEmbedded layer
  • pvr — the command line tool
If you spot anything missing, broken, or out of date, let us know in this thread — feedback on the new docs is very welcome.
Happy hacking!
Big step on pantavisor docs for sure… Amongst everything, I like how it supports AI coding agents. Just ask:
"Help me understand and set up Pantavisor. Read ``https://docs.pantavisor.io/llms.txt`` first, then walk me through it step by step."
Good tip. Since the docs are now versioned, it may also help to tell the agent which release you’re targeting before it reads llms.txt — otherwise it might walk you through the latest reference rather than the one matching your device. For older releases, pointing it at the version-specific path first could avoid mismatched pvr commands. Worth adding a note about that to the AI-agent instructions if it isn’t already covered.
