We are happy to introduce a new feature in PVR along with the personal tokens, that allows pvr to read your .netrc file and use the credentials saved in there to authenticate any action on pvr against using those credentials.
The .netrc input for PVR will look like this.
machine api.pantahub.com
login PERSONAL_TOKEN_NAME
password PERSONAL_TOKEN_SECRET
After that, you will be able to execute pvr login, pvr get, pvr post or any other action on pvr that needs access to our could system without the need to use the interactive mode to set the username or password
We added some new arguments to pvr to accomplish the same if you don’t want to use .netrc. The new global arguments for pvr are:
GLOBAL OPTIONS:
--user PVR_USERNAME, -u PVR_USERNAME Used for authentication with core services, you can use the environment variable [$PVR_USERNAME] too
--password PVR_PASSWORD, -p PVR_PASSWORD Used for authentication with core services, you can use the environment variable [$PVR_PASSWORD] too
This allows to use the arguments on the CLI like this:
pvr -u USERNAME -p PASSWORD login
Or using environment variables like
PVR_USERNAME=yourusername
PVR_PASSWORD=yourpassword
pvr login
