Hi,
Pantavisor images by default connect to hub and don’t open the local management port needed to interact with your device locally directly by default.
The process of changing that requires some manual interactions after install, which are not needed if you configure the image properly.
To avoid that I have made a custom image link that instructions our image-service to mangle the right configs into the image that will make your Install automatically come up pre-configured and with ports open so you can get started right away.
- RC image for local pantavisor development: https://bit.ly/pantavisor-rpi64-5_10_y-rc-local-dev
- RC image for local pantavisor development: https://bit.ly/pantavisor-rpi64-5_10_y-stable-local-dev
Once installed, get network like documented here for instance: First Boot - Docs
And off you go.
Try http://IP.OF.YOUR.TARGET:12368/app in your browser to get live logs and more.
And of course pvr clone to your device right away:
pvr clone IP.OF.YOUR.TARGET
cd IP.OF.YOUR.TARGET
pvr app add --from=nginx:latest nginx
pvr add
pvr commit
pvr post -m "add nginx"
